Single amp: 2000 watt RMS info requested
Old May 21, 2007 | 07:30 PM
Rysonx's Avatar
Default Single amp: 2000 watt RMS info requested
I'm looking for an amp that handle 2000 watt RMS and want to ask you people which brand is good and has solid quality.
Looked over Rockford Fosgate model T20001bd and found one on ebay for about 700 bucks. I'm looking for decent price on those kind of amps which price range goes for like 500 or lower ( i wish) to like 800 bucks.
I don't mind dual amps but its taking up way too much spaces and placing it on the back of the rear seats is not quite my kind of idea so will like to place it in the spare tires area to hide it and ease of install.
throw down a list of name and pictures if you like.
Old May 21, 2007 | 07:34 PM
L4rry_B1rd's Avatar
kicker zx2500.1
Old May 21, 2007 | 07:41 PM
Rysonx's Avatar
I forgot to mention it before. im looking for mono channel amps and also make sure you give me the full model name and numbers so i can look it up
Old May 21, 2007 | 07:56 PM
Luc1f3r's Avatar
Originally Posted by L4rry_B1rd
kicker zx2500.1
x2!
i have a zx1500.1 and zx 450.2 in my tC....
http://www.hookedontronics.com/show_....jsp?cid=18863
Old May 21, 2007 | 07:59 PM
L4rry_B1rd's Avatar
not as ballin as you but I have:
zx750.1 and zx200.2... and I love them
Old May 21, 2007 | 08:02 PM
nodsetse's Avatar
What sub(s) will it be driving? Helps to state what the load will be, to ensure the amp can handle it and meet your power requirement per the impedance you'll be using.
Old May 21, 2007 | 08:11 PM
Rysonx's Avatar
Just got dual MTX 9512-44 and each of them handle 1000 RMS
Old May 21, 2007 | 08:38 PM
nodsetse's Avatar
Aren't those 4 Ohm DVC? If so, and with all parallel wiring, that'd be a 1 Ohm load on the amp.
So you're looking for the least expensive mono amp that does 2000 watts at 1 Ohm, right?
And you know that just because they can handle 1000w, that doesn't mean you need to give them that much, right? Fine if you want to, but it's definitely not required.
Old May 21, 2007 | 08:53 PM
Rysonx's Avatar
yes they are 4 ohm DVC and yes i know i dont have to give them that much but i just want to have the amps that match its performance. just want to make my bucks worth it. Dont want to get a cheap amps that doesnt bring the full power of 9512.
EITHER GO BIG OR GO HOME.
Old May 21, 2007 | 09:43 PM
r0cky1nyc's Avatar
i just ordered the mtx 9500 subs but in 10">
What you need is an amp that has 2000rms at 1 ohm.
The closest thing is the mtx thunder elitre 1501d its msrp is 899.99.
I currently have that amp and its great> However it takes up alot of power.
Amp puts out 1500rms at 1 ohms. Bith sheet stated it tested at 1700rms.
good luck
Old May 21, 2007 | 10:22 PM
Rysonx's Avatar
hmmmm found new one for 400 bucks.. maybe 1500 RMS will do just fine.
Old May 22, 2007 | 02:58 AM
trialsindude's Avatar
Strictly Scionized
I beg to differ, if a sub RMS rating is 1K feed it 1k of power. My sub is rated a 1k and I am feeding it 1506watts...
Anyways...
Look into Sundown Audio if you want rated power. They have the new SAZ-1000 which will give 1k@1ohm, if you would have gotten in on it early for their pre-buy could have picked 2 of them up for $450 shipped. MSRP for those amps are $399, if you find a dealer it will prolly be cheaper.
Orion D5000 amp it will put out 2500@1ohm.
Lanzar Optidrive 2000d roughly 1800@1ohm
Just a few to start out with....
Old May 22, 2007 | 03:07 AM
Tcguy85's Avatar
sundown audio! i want the saz1500 so bad. when i upgrade my equipment that'll be my amp.
Old May 22, 2007 | 10:57 PM
nodsetse's Avatar
Anyways...
Care to state why? Disagreeing doesn't do much good without rationale for such.
Yes, you can supply a sub with it's RMS rated power, and you can often safely give them more if done correctly. However, it's not always necessary to give them that much in order to meet a person's system requirements. There are may aspects that should be considered when determining how much power to give a sub or other driver, so I have to disagree with what you stated, because you didn't qualify your implication.
Old May 22, 2007 | 11:19 PM
Rysonx's Avatar
i found mtx thunder elitre 1501d for 400 bucks and its 1500 rms but for 2000 RMS,, most amps will cost like 700 to 800 dollars.. am thinking if 500 more watt rms will worth having to pay 300 to 400 dollars more.
Old May 22, 2007 | 11:22 PM
Jan06xB's Avatar
Just so you all know - 1000 watts RMS will require 1414 watts peak PLUS more power for amplifier losses. This is due to the FACT that RMS is the Root Mean Square of the SINE wave feeding the speaker and the peak is 1.414 times greater than the RMS of a sine wave. If you drive it that hard you will need to be able to supply it with that much power wich from a 12 volt battery comes out to around 150 amps give or take a few dozen depending upon battery voltage. If you want more sound then get more efficient speakers.
Old May 22, 2007 | 11:34 PM
Strictly Scionized
I dunno man 90.7dB 1W/1m then able to do 141db with stock electrical is impressing...
Old May 23, 2007 | 07:58 PM
nodsetse's Avatar
In that case, do the smart thing and go with 1500w.
If the subs output stayed linear and didn't suffer from compression at such power levels (dream on), then the additional 500w would only get you 1dB more SPL. Besides that, you'll often only be using <100w, except when you're trying to wake the 'hood or go deaf and actually push the 1500w.
Wrencher
May 24, 2018 10:15 AM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
StxArOne
Jul 13, 2015 06:25 PM
goatbelly
Jul 12, 2015 10:13 AM
