Injen Intake vs. 18inch Wheel vs. S-techs Problem(pics)
Old Jul 2, 2007 | 05:19 PM
KickAssKishan's Avatar
Default Injen Intake vs. 18inch Wheel vs. S-techs Problem(pics)
I have been having this rubbing issues on my driver side wheel for some time now, and recently took the bumper off and noticed that, there is a huge hole in my wheel welll because of it...
Whats happening is that my INJEN intake cone is pushing the wheel well about an inch or so towards the wheel, normally this wouldnt be a big deal, but because im on the s-techs(2.5 drop) its rubbing horribly, not to mention wheels are 18 x 8.5 ....Anyway the rubbing has gotten so bad that support rod coming out of the intake (cone portion) connected to the car..is acctually bent....
Ive come to two main conclusions on why this is happening...
1) Bad Install
2) Wheels are too wide...
When installing the Injen intake did anyone else notice the cone pushing the wheel well? For any help please comment...pics are below
Old Jul 2, 2007 | 05:27 PM
ack154's Avatar
im in ur posts, fixn ur pix!
Old Jul 2, 2007 | 05:29 PM
ack154's Avatar
Oh, and I'm pretty sure you installed that intake on the wrong side of the lower mount. The vibramount should go the other way, facing the front and the intake should mount there. I think that's it anyways...
Old Jul 2, 2007 | 08:39 PM
Ack can u send me a PM with more detail and maybe an arrow or two at my pics, idk if im assking for too much but it would be soo greatly appreciated
Kishan P.
Old Jul 2, 2007 | 09:55 PM
rspectc's Avatar
just go short ram...
Old Jul 2, 2007 | 10:46 PM
ack154's Avatar
Kishan P.
So if you look at your 4th pic, you can see the vibramount (rubber mount thingy) is to the right of the hole it's mounted into... it's supposed to be the other way. It screws in from the other side.
The order you have it and it appears in the photos:
[ body of car ] - [ rubber piece ] - [ intake mount ] - [ nut to secure it ]
Looking at it from the view of the picture, they should be in this order:
[ nut to secure it ] - [ intake mount ] - [ rubber piece ] - [ body of car ]
That make sense?
Old Jul 3, 2007 | 01:23 AM
I understand the first order but not soo much the secound how do i put the nut to secure it inbetween the intake mount and rubber peice i though the rubber piece purposely was inbetween so the cone would be pushed that inch or however so...
Thanks
Kishan P.
Old Jul 3, 2007 | 01:32 AM
ack154's Avatar
The nut goes on the outside of the intake mount.
This is the best pic I can find at the moment, maybe it'll help though:
Viewed from the front of the car...
Old Jul 3, 2007 | 01:33 AM
amdforever's Avatar
the rubber piece is there to prove a small amount of flexiblity in the system but to absorb vibrations as well. I too think you put the mount on the wrong side of the bracket.
Old Jul 3, 2007 | 01:46 AM
tc-guy's Avatar
its kinda hard to make out in the pic but if u had installed it that way the intake would be like at least a couple of inches away from the fender splash guard. if it was installed the way it is in the pic it would not have been close enuff to rub when u turn ur wheels.
Old Jul 3, 2007 | 03:42 AM
Is this true when the car is lowered too?
Thanks for all the help guys first thing tommorow I am going to attempt to fix the problem..
Kishan P.
Old Jul 3, 2007 | 02:30 PM
ack154's Avatar
Let us know how this works out... keep in mind you might have to loosen the middle coupling near the MAF since the pipe will probably have to rotate or something to go into the proper position.
Old Jul 4, 2007 | 03:36 AM
holaplaneta's Avatar
damn son no wonder!!!
Old Jul 4, 2007 | 05:43 AM
Took 5 to 10 mins...No more rub..No more embarassing right turns...I love SCION LIFE!
Thanks for the help guys!
Kishan P.
ahaha Chris I fixed it man
Old Jul 4, 2007 | 02:39 PM
ack154's Avatar
Glad you got it straightened out. Just one of those "oh, duh" kind of things I think.
Old Jul 4, 2007 | 03:22 PM
good! im glad u fixed it, i was in pain everytime u turned the wheels!!!
Godfryness
Jan 2, 2015 11:18 PM
minter66
Dec 15, 2014 01:45 PM
Joeynenj
Nov 25, 2014 05:29 AM
arinvolvo
24
Nov 2, 2003 05:30 AM
eric_m
29
Oct 12, 2003 08:22 AM
