Scion tC 2G ICE & Interior In-car entertainment and electronics...
Annoying tapping sound!
Old Jun 13, 2011 | 07:46 AM
nolakpd504's Avatar
Default Annoying tapping sound!
There's an annoying tapping sound coming from the b pillar on the passenger door(i believe thats where its coming from) whenver i hit a bump in the road. Anyone else has this problem or how they fixed it? Sounds like something rubbing on the paint.
Old Jun 13, 2011 | 06:48 PM
tyap's Avatar
I've been having problems with these annoying noises since I bought the car 6 months ago.
Is your noise coming from b-pillar or is it more from the roof area? Did you have other people ride with you trying to locate where it's coming from? It could sound like it's coming from different place when you're on the driver seat compared to the passenger seat. How often does it make the noise and what speed? Only when it goes over bumps and at speed higher than 20 mph?
Mine is coming from the top of a-pillar probably from the roof area. Some people say it sounds like it's coming from the top of b-pillar. It makes a high pitch ticking noise like a small stone hitting the windshield. It started only when going over bumps but it keeps getting worse and it makes the noise constantly. It stops making the noise when the car sits under the sun for a while. I brought the car in 3 times, but it's still making the noise. When they say they fixed it, the noise is gone only for a week and then comes back.
Here are some other threads you might want to check out:
https://www.scionlife.com/forums/sho...d.php?t=196904
https://www.scionlife.com/forums/sho...d.php?t=198551
https://www.scionlife.com/forums/sho...d.php?t=202140
Old Jun 21, 2011 | 11:23 PM
BlackCloudz's Avatar
Default Found it.
I've found the noise. While having my wife drive the car I sat in the back, on the passengers side. Used my ear to narrow down the area. Pulled the cloth gasket forward to separate the head liner, and found it. The noise got louder when I pulled down the head liner. Put my ear up to the area to confirm. Shoved my hand up there and put pressure on the roof metal and noise went away. See pictures. This area is located behind the rear seat sun roof, on passenger side.
Attached Thumbnails Annoying tapping sound!-img_2686.jpg   Annoying tapping sound!-img_2692.jpg   Annoying tapping sound!-img_2689.jpg   Annoying tapping sound!-img_2696.jpg
Old Jun 29, 2011 | 06:08 PM
tyap's Avatar
Did you do anything to get rid of the noise?
Old Jun 29, 2011 | 06:15 PM
Yes layed 2 papers towels down onto the head liner below metal (___ seen in pictures) and sprayed liberally with WD40. Noise has not come back. I left the doubled up paper towels up in the area, and sealed it back up, by pushing the cloth gasket/ring back into place.
Old Jun 29, 2011 | 06:18 PM
the 3rd and 4th pictures above show the metal and head liner separated. This is where I laid some paper towels and sprayed WD40 with one of those red straw things attached to it, to direct the flow up onto the metal creaking area... hope this helps....
Old Jun 29, 2011 | 06:21 PM
tyap's Avatar
I tried opening it up to stuff a towel in between that metal and the headliner to put a little pressure, but that didn't help.
I'll try WD40 when I have a chance.
Thanks for the info!
Old Jul 25, 2011 | 01:28 PM
2011crimson's Avatar
I have this tickin going on as well. It sounds to me like it is coming from that area. it is not real bad, and with the stereo on, i seldom notice it. I plan to have the dealer check it out at the free maintenence coming up.
Not sure if it is coming from the same place, but this is good info.
Old Jul 25, 2011 | 02:55 PM
usafscion's Avatar
Wow that sucks...new ride ...
Old Aug 30, 2011 | 07:34 PM
tyap's Avatar
I'm stil having this noise problem.
Those who have the same noise problem:
* What color is your car?
* Does the noise go away when your car gets hot after sitting under the sun for a while?
* Do you always park in the covered parking?
Old Aug 30, 2011 | 09:04 PM
rackatak's Avatar
I am having the same issue. I notice it in both hot and cool weather. It has been consistently 100 degree days here in Texas so I don't know how it acts in cold weather. I park out in the open day and night. I hear it at all speeds. I'm going to have the stealership check it out when I go in for scheduled maintenance.
Old Oct 2, 2011 | 05:15 PM
Chrislbz's Avatar
I have the same problem and its a 2011 Cement. Going into the dealership Monday night
Old Oct 9, 2011 | 06:07 AM
Dominion's Avatar
I have a very similar situation with the sunroof. But when I turn up the stereo the tapping goes away?
archael666
Mar 19, 2019 11:52 PM
halosinfire
Scion tC 2G Forced Induction
Jun 10, 2015 05:21 PM
corbmonster
Jan 24, 2015 05:22 PM
Inazuma
11
Jan 10, 2004 09:39 PM
