k&n rattle
Old Apr 4, 2005 | 01:30 AM
VoLktc's Avatar
Default k&n rattle
has anybody had a prob with their k&n cai rattling? i have re tightened everything and it still rattles when i go over something bumby
Old Apr 4, 2005 | 01:59 AM
TheBlade's Avatar
my bumps everytime I accel/decel...I checked everything, everything was tight...I'm thinking its rubbing on the inside of the fender..here's my fix for it so it doesnt rub anymore, but I still hear it:
As you can see I used a piece of vac line from my old BOV on the Escort and then used my pocket knife to cut it lengthwise..then slid it onto the fender lip where the intake was rubbing a little bit. Other then that ...I'm thinking it might be the stiff silicone hose connecting the intake to the throttlebody.
Hope the image helps...here's a bigger view, but blurry from my crappy camera phone.
Old Apr 4, 2005 | 02:26 AM
KINGxOFxSKA's Avatar
Unique Scionikz
i noticed the rattle sound in the low rpms when pulling out of the street in front of my house. i used the soft side of a velcro strip and lined the metal with it. no more rattle. :D
theblade... your BCP tC looks almost like the hot lava color in those pics. cool
Old Apr 4, 2005 | 04:36 AM
VoLktc's Avatar
ive noticed where it was rubbing on both sides but on the bottom i put a rubber gasket and i almost couldnt make it rattle but on my road (gravel) it rattles like no tommorow it drives me nuts. i line the top tommorow any more input is very aprecciated
Old Apr 4, 2005 | 01:18 PM
ScionDad's Avatar
No rattles here, it took quite a while with the wheel off to align it and tighten the hell out of it, before putting back together. I read several threads about rattles, so I made sure the CAI was in the middle of the opening.
Old Apr 6, 2005 | 03:49 AM
NorwalkTc's Avatar
I asked this in another thread, but do any of you have a whistle at 3K, and at shifting points? I think all of my connections are tight, but it still makes the noise... Any suggestions?
Old Apr 6, 2005 | 11:43 AM
vanberge's Avatar
might just be your air flow.... im sure that you'd be able to hear it sucking in at it's peak (insert joke here)
Like my friend put an injen intake on his saturn, and it sounded like a vaccum cleaner.
But I'll let you know if i have similar experiences with my K&N.
Should be here 3-5
Old Apr 6, 2005 | 05:45 PM
VoLktc's Avatar
problem solved it w a s n o t the intake it was actually the tie rod on my coilovers (got in a wreck of sorts) and yes i do get the sound you are talking about it. i think its just the throttle body closing the valve when you shift forcing some air out?
Old Apr 12, 2005 | 05:37 PM
tc05's Avatar
Has the CAI made your CEL come on? im getting mine on friday from vividracing.com
Old Apr 12, 2005 | 05:43 PM
ScionDad's Avatar
Nope, no CEL. Once you put it on, let the car idle for 5 minutes so the ECU can sense the difference and adjust.
Old Apr 12, 2005 | 05:44 PM
tc05's Avatar
Thanks, i herad the install is about and hour maybe longer any good pointers to make it a lil faster but done right at the same time
Old Apr 20, 2005 | 01:52 AM
tc05's Avatar
I also have that whistle at 3k and at shifting seems like all my connections are tight, does any one else have this noise or is just me and the other guy, and yes aligning the bottom pipe is a pain i swear i spent more time on tha more than anything, but no rattle
Old Apr 20, 2005 | 03:02 AM
Mx6GT91's Avatar
The whistle is normal. The car does that stock its just a lot louder with the intake. It seems like no one on this site has ever heard a car with an intake......hahah
I used some hose to stop the rattling on my moms car. When I sold the intake I included the hose also.
Old Apr 23, 2005 | 07:02 PM
vanberge's Avatar
I think I fixed the rattle for good, with no additional pieces.
Mine had been rattling when accellerating...
After awhile of loosening and reworking the mounting brackets, I found that the "little rubber" nobby that the mounting bracket is bolted to was the problem. The weight of the K&N had settled it a bit, so the K&N was sitting about a quarter inch lower than when i originally did the install (hence, rattling when vibrating).
What i did finally, was loosent he "Z" bracket's mounts, and rotate it clockways about 2 inches. This positioned the K&N perfectly, and havent had the rattle since.
Another thing though, make sure you tighten the bracket at the rubber stoppy first, then tighten at the actual intake pipe.
Hope that helps you guys!!
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
mxwes
Aug 30, 2015 09:11 PM
BadCattitude
Aug 29, 2015 01:10 AM
SFXB
Jul 9, 2015 11:00 PM
