@@@~~~HORRIBLE@@@~~~
Old Apr 24, 2009 | 04:13 PM
  #41
Syldrin's Avatar
That oil looks like that crappy foam ptuning puts in their boxes they ship the exhausts in.
Old Apr 24, 2009 | 04:54 PM
  #42
CarbonXe's Avatar
That foam is actually really good for shipping. Much better than bubble wrap, peanuts, or those airbags. The only reason I could think of it being crappy, is that it takes forever to get the exhaust out of the box .
Old Apr 24, 2009 | 06:20 PM
  #43
nlataille18's Avatar
x2!! ^
Old Apr 24, 2009 | 06:23 PM
  #44
BTW that's what oil looks like when you add water to it and run it in your engine. Did a little off roading back in the day, that's how i know... haven't done it personally
Old Apr 24, 2009 | 06:26 PM
  #45
CarbonXe's Avatar
Or coolant, it's a tell-tale sign of a coolant leak.
Old Apr 24, 2009 | 06:40 PM
  #46
but from where. wouldn't he have to have cracked his head to get coolant into his oil. if it was head gasket to cylinder then he would just burn the coolant before it could seep past the rings. unless it was block damage like coolant sleeve to mid engine area... then it could possibly make it's way to the oil.
Old Apr 24, 2009 | 06:42 PM
  #47
either way it should be covered under warranty!
Old Apr 24, 2009 | 07:12 PM
  #48
gp1817's Avatar
correct..should all be covered by a warrenty that what warretny are for unless they some how find and excuse thats its your fault but all geniune and nice people should work with you on this problem if they give you B.S i wouldnt deal with them
Old Apr 24, 2009 | 08:15 PM
  #49
vettereddie's Avatar
The engine doesn't have to run for the oil to turn to peanut butter. Just look at the water traps around any place where you go to recycle oil. Also, this happened on my last engine build. Drained the oil from the engine on a stand, then pulled the water pump. Coolant leaked out into the oil pan and a few days leter there were sections of light brown.
There was also some in the bottom of the engine oil pan. The block had been sitting in a salvage yard for over a year, so no doubt some water leaked in. There was no sludge or other buildup on any of the moving components, so I assumed water had just collected in the pan from humidity, etc as it sat, it got rained on at some point, or got contaminated when they pulled the engine.
Oil passages pretty clean and normal:
Peanut butter in the bottom of the pan:
If there's goop it may have happend when the rod broke and coolant mixed after failure.
Old Apr 24, 2009 | 09:26 PM
  #50
jigstC's Avatar
they better get you a brand new tc
Old Apr 25, 2009 | 02:01 AM
  #51
iqbokc's Avatar
i change my motor oil every 3 months or 5k miles and uses mobile 1 and a fram filter. for the ppl who mentioned about the powertrain warranty thanks! im gonna call them tmw...thanks for the heads up
Old Apr 25, 2009 | 03:49 AM
  #52
Syldrin's Avatar
Threaten to sue man.
and carb X3 on the only disadvantage to the foam. great stuff for packing for sure.
Old Apr 25, 2009 | 07:27 PM
  #53
Yeah, PTuning goes overboard on the packaging. I orded an Injen Hydroshield from them, it's jsut a sock in a bag, but they packed it in a cardboard box three times as big as it, and with padding.
it could have been air dropped in a hurricane and it would have survived.
Old Apr 26, 2009 | 06:59 AM
  #54
07tctul's Avatar
haha no engine mods......
no engine lol
Old Apr 27, 2009 | 05:36 AM
  #55
gompka's Avatar
Your in Chicago, country side scion, elmurst toyota, and grossinger scoin in skokie are 3 dealerships that will most likely tell you that you overreved the engine and its your fault it blew. Just giving you a heads up on my experience with those 3 dealerships. They tried to tell me that my shaft on the s/c was ok and then later after i showed them how messed up it was, they said it was because i had a gutted cat, because less heat in the header causes shaft damage right? ;) lol
Old Apr 27, 2009 | 06:35 AM
  #56
fury575's Avatar
The dealership will say anything at first to try and get out of having to pay for it. Just gotta stand up for yourself and tell one of the managers your in the process of talking to lawyers about it then take it from there.
Old Apr 27, 2009 | 06:40 AM
  #57
gompka's Avatar
I had a lawyer send them a threatening letter, and that didn't help. Hope it works out for you man. If not its not too bad you can pick up a new engine for $600ish. There are a million camarys around lol
Fisqual
Sep 22, 2015 05:51 AM
StxArOne
Jul 13, 2015 06:25 PM
D_Roke
Mar 31, 2015 05:37 PM
Dapitt84
Mar 4, 2015 02:03 AM
hossb12
Feb 22, 2005 07:01 PM
