trouble making power up top...help!?
Old Mar 3, 2009 | 11:56 PM
  #81
rozz-tC's Avatar
Interesting. What gave you the indication it was maxing out?
ultimate logs, at full boost i was anywhere from 5.0-5.7v It also threw a MAF voltage high code. Which ____es off the ECU and according to ptunning, makes the car dump fuel like a garden hose and starts eating timing like tic-tacs. He was also hoping it would account for my misfire, which it may have. Wont know till i get a scan, but im still getting some stutter at high RPM accel.
Old Mar 4, 2009 | 12:07 AM
  #82
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by toyota_scion_tc
Are you converting to a blow-thru setup? If not, you will have trouble having the MAF installed on a 3 inch intake.
Unless you are on a standalone.
LOL.
Ultimate will also. Remember, PTuning's kit is a blow thru type and they were running the Ultimate.
Old Mar 4, 2009 | 12:12 AM
  #83
Music City Scions
What is the max the MAF should stay below.
Old Mar 4, 2009 | 12:26 AM
  #84
rozz-tC's Avatar
5.0v is the max, The way it was explained to me tho, anything over 4.8v starts to get hairy with the ECU. I was told to clamp mine below that point, then re-tune fuel. Which i did, then cleared the code. and the car instantly gave me back like 5-7 degrees of timing (from 10-12* to 15-17* ), So even with me pulling more timing (again suggested by ptunning) im still running more advance than it was previously. Before the clamp, I was pulling 1* and running at about 12* down to 10*, now with pulling 2* at 6psi, 6* at 8psi, 8* at 10psi. the car still runs around 15* or so. Once on a dyno he said I can bring the timing back up to make my power, but for tuning fuel on the street to leave it how it is. Once I'm sure im not misfiring, or fix it if i am. Then ill schedule some dyno time and give it a final tune.
Old Mar 4, 2009 | 12:27 AM
  #85
toyota_scion_tc's Avatar
4.99 Volts or 5.0 Volts
Old Mar 4, 2009 | 01:28 AM
  #86
Music City Scions
I think I'll check my old logs to see what mine was running. Just when you think you got this tuning thing under control, some other things can be tweaked...lol.
And +1 Toan from PTuning does know his stuff. He helped me diagnosis a starting problem with the Ultimate in like 20 mins, after I told him my situation.
Old Mar 4, 2009 | 01:32 AM
  #87
rozz-tC's Avatar
Yeah, but damn i wish they were closer to me! lol However...they prolly dont
Old Mar 4, 2009 | 01:42 AM
  #88
Music City Scions
^^Yeah know what you mean. I'm 10 hours away from them.
Old Mar 4, 2009 | 02:09 AM
  #89
dave2610's Avatar
+1million for taon he's the man
Old Mar 4, 2009 | 01:37 PM
  #90
paul_dezod's Avatar
Scionetics
KAD
LOL.
Yep! With the standalone you can run a 5" intake and it won't matter.
Old Mar 4, 2009 | 04:06 PM
  #91
Music City Scions
LOL.
Now that I reread what was written, if the MAF is still in the stock setup location and you run a larger than 2.5 inch intake, then yeah probably a Standalone is best. But for a blow-thru setup, of course you don't need to run a standalone. Sorry Nick, I thought you were talking about running the blow-thru setup and needing to have a standalone for that.
Old Mar 4, 2009 | 05:11 PM
  #92
LOL.
Its cool if it were someone else though it wouldn't be! JK
Old Mar 5, 2009 | 01:48 AM
  #93
Music City Scions
^^That's my dog.
2CTC
Sep 12, 2015 11:33 AM
BV19869
Dec 11, 2014 06:05 PM
bBOXD
12
Aug 30, 2004 05:30 AM
