DIY: Switchblade Key Conversion
Old Nov 28, 2009 | 03:25 AM
  #141
O5_TRD_tC's Avatar
I just got the key and got it cut and assembled it. Looks and works great. Just found out the Buzz button is on the wrong side...
Also Ack are your Lock/Unlock buttons flipped?
Old Nov 28, 2009 | 05:20 PM
  #142
ack154's Avatar
Don't recall exactly which way they are compared to the others... but those little silver buttons can be switched, so if they are "wrong" on the key, just swap the button pieces.
Old Nov 28, 2009 | 06:02 PM
  #143
O5_TRD_tC's Avatar
I know they can be switched. But my lock and unlock is flipped compared to yours.
Also does your panic button work?
Old Nov 28, 2009 | 08:30 PM
  #144
ack154's Avatar
My buttons work as pictured... so it is possible I have have swapped them when I put it back together, I really don't recall.
I don't know about the panic, I assume so - but I've never tried it.
Old Nov 28, 2009 | 10:16 PM
  #145
O5_TRD_tC's Avatar
I think you might want to check that out. Lock should be on the right side.
Old Nov 29, 2009 | 05:16 PM
  #146
ack154's Avatar
If I look at mine holding it with panic to the top, unlock is on the right and lock is on the left. So I must have swapped them.
Old Dec 28, 2009 | 03:55 AM
  #147
AZGuy's Avatar
Anyone know where I could get the key without the guts? Only the complete keys are on ebay now.
Old Jan 5, 2010 | 08:38 AM
  #148
O5_TRD_tC's Avatar
yeah I noticed this when I was going to leave the seller a feedback but he had already deleted his ebay account.
Old Jan 14, 2010 | 02:31 AM
  #149
stephen6119's Avatar
Hey, so I got the key off of ebay and went and got it cut using the code at the toyota dealer, but it turns out that the machine at the toyota dealer is not able to cut the tip of the key, which leaves the tip of they key too wide (I assume its not as wide on blank toyota keys) and it won't work in my car and every other place i've been to (Ace Hadware, Home Depot, etc) said they don't cut car keys.
Any advice on how to get the end of the key cut?
Old Jan 14, 2010 | 03:51 PM
  #150
ack154's Avatar
Keep going to hardware/home stores. Someone will cut it. Those that say they can't/won't are just lazy or stupid.
Old Jan 26, 2010 | 04:45 AM
  #151
AZGuy's Avatar
Someone on Ebay selling just the case, he does have a cheaper shipping which I still think is a bit high but hey its still less than the key with guts.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Jan 27, 2010 | 05:43 PM
  #152
chowee21's Avatar
Very Nice, I got caught up and never got to finish my project, but i just ordered that housing and will be doin this! NIce WOrk!
Old Jan 27, 2010 | 05:47 PM
  #153
O5_TRD_tC's Avatar
For those of you having issues with getting the key cut at home depot/lowes.
I used to work at lowes and their machines have this blank. The first thing they will tell you is you have a chip in your key and it wont work. Well just tell them to ignore that for now and find the blank for your stock scion key. If their machine is an Axxcess the blank key is #35R.
Tell them to pull the cartage for that blank (35R). Now, give them your blank flip key and instruct the worker to use your blank instead.
Ta Da, you got your key cut for free!
Old Jan 28, 2010 | 03:01 AM
  #154
AZGuy's Avatar
Great info, thanks!
Old Jan 28, 2010 | 08:46 AM
  #155
O5_TRD_tC's Avatar
np
Old Feb 4, 2010 | 09:29 PM
  #156
chowee21's Avatar
So im hella ____ed because i just got my key, and it has Honda logos, and the grooves aren't cut on the top and bottom of the key itself.. Should i just get my money back or is there somthing i can do to get the grooves cut?
Old Feb 4, 2010 | 09:33 PM
  #157
ack154's Avatar
Sounds like you either ordered the wrong thing or he shipped the wrong thing. I would just contact the seller and try to get it exchanged before doing anything else.
Old Feb 4, 2010 | 09:48 PM
  #158
06tcdude's Avatar
Unlock is on the left, lock is on the right, and panic don't work.
and since the transponder was acting up, the metal cover doesnt stick right. good thing it comes with two covers. i will put on the second one when i am sure the transponder is in there right and i dont have trouble starting the tC
Old Feb 5, 2010 | 08:12 PM
  #159
boxerrebellion's Avatar
sorry for this question but according to the ebay auction: http://cgi.ebay.com/ebaymotors/2005-...item35a6b2d7a5
the guy will put in a transponder for us. does that mean i should take that transponder out and put in the one from my original key? or should i ask him/her not to put it in at all?
if he has a transponder in there already, that means i will need to program (add my key) according to the instructions on the first post?
so aside from getting it cut, everything else should just be transfer and some super glue right?
Old Feb 5, 2010 | 08:14 PM
  #160
ack154's Avatar
I think you have to ask the seller to put one in for you - so I just would not bother doing that and use the one in your current key (assuming you're replacing one).
