Hidden Slim 10" box..updated with it's evil twin and am
Old Dec 19, 2006 | 09:27 PM
  #261
zm_br's Avatar
pm sent, there good buddy
Old Dec 19, 2006 | 09:39 PM
  #262
Doanrs's Avatar
Originally Posted by zm_br
my box has been "in the woodshop" since 12/11, which was a week ago yesterday. Use of special glue that takes 128 hours to cure? Anybody else's take a whle to be built, or do you think that my box is in the mail and my account status just hasn't been updated?
chris, any insight? i'm order 7327, if that helps. i'm just curious, not complaining. i already have my sq10, and NINe.2.
awesome, thanks.
I'm still waiting too (order 7289)....no worries. Any idea when the nine.4 will be back in stock?
Old Dec 20, 2006 | 02:40 AM
  #263
Thermalzeal's Avatar
Im suprised you guys havent bought a cnc water jet yet.
Old Dec 22, 2006 | 08:30 PM
  #264
StevieSoFly's Avatar
ok... im sorry im not really good with all this audio talk but i was just wondering if i got the SQ10 sub should i get a S2 or S4 voice coil and... which amp should i get? the NINe.2X or NINe.2??
Old Dec 22, 2006 | 09:30 PM
  #265
BumperLT's Avatar
The voice coil depends on how many speakers, and what amp you are/will be using.
Old Dec 23, 2006 | 02:17 AM
  #266
ok.. say i want just one sub which amp should i get and which sub?? and i think im going to be using it with my stock ipod H/U until i get money for a double din DVD
Old Dec 23, 2006 | 02:24 AM
  #267
BumperLT's Avatar
if you get a 2 channel amp is has to be bridged.. usually into 4 ohms cause most amps can't handle 2 ohms bridged. If you get a mono sub amp, then you can get a 2 ohm sub.
Old Dec 23, 2006 | 06:58 AM
  #268
so.. which amp and which sub from E.D should i get then?
Old Dec 23, 2006 | 11:02 AM
  #269
SCI_TC_GUY's Avatar
From Elemental Designs, an SQ10 S4 and a Nine.2....
OR...
You could get an SQ10 S4, Nine.4 amp, and eD(i)6000s or 6500s components for the front.... Bridge the 2 rear channels to the SQ10 and run the front 2 channels on the components - would be killer!!!!!
Old Dec 23, 2006 | 05:42 PM
  #270
ok so would i be safe if i did a SQ10 S4 and Nine.4 amp incase i want components later on?
Old Dec 25, 2006 | 01:40 PM
  #271
arbnpx's Avatar
Anyone have pictures of their setup yet? I was trying to visualize where the amp would go if I wanted it to be not easily visible (and keep my spare tire as well). Of course, with the cargo cover attached, it wouldn't matter that much.
Old Dec 25, 2006 | 03:14 PM
  #272
Golden86's Avatar
You could put your amp in the spare tire like I did. I used an Alpine amp, but I think the ED amp will fit in the same spot.
Old Dec 25, 2006 | 10:10 PM
  #273
have u guys seen this?...
http://www.youtube.com/watch?v=OoVIF...elated&search=
Old Dec 25, 2006 | 11:26 PM
  #274
arbnpx's Avatar
oh, right. I didn't notice the amp the first time I watched that video. And it definitely has the cover on.
Old Dec 26, 2006 | 12:15 PM
  #275
SCI_TC_GUY's Avatar
That's correct.... you'll need a Single 4ohm VC to match with the nine.4. Components will definitely add to the overall SQ...
Old Dec 26, 2006 | 01:40 PM
  #276
theman0521's Avatar
I am planning on ordering the sub today, but have no knowledge of this voice coil stuff, I read the page on it and still am confused. I have a MTX 251D amp. I am not expecting much, I just want some sort of extra bass, without having a box in the back. Tech support is closed until the 27th, so I figured I would ask here. I found these specs on my amp to make it easier. Hopefully this will make telling me what I need a little easier.
RMS Power 14.4 VDC
Input
Hi Level w/ Smart Engage
Low Level Input
Crossover
18dB/Octave, 85 Hz
2 Ohm Load 200 w x 1
4 Ohm Load 100 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 250 w x 1
4 Ohm Load 125 w x 1
Dimensions (with ISO Feet)
7.98" x 9.75" x 2.1"
20.3cm x 24.8cm x 5.3cm
Old Dec 26, 2006 | 02:03 PM
  #277
SCI_TC_GUY's Avatar
With the 251D, You should get a Single 2ohm voice coil sub...
If you were going to get 2 SQ10's, you'd get the single 4 ohm in both subs and wire them in parallel for a 2ohm load....
Bottom line: for 1 sub on the MTX 251D - Get a single 2 ohm sub
Old Dec 26, 2006 | 02:15 PM
  #278
theman0521's Avatar
Just to be clear would be the s2 option, correct?
Old Dec 26, 2006 | 02:16 PM
  #279
SCI_TC_GUY's Avatar
^^ yes
Old Dec 27, 2006 | 04:01 AM
  #280
HondAudio's Avatar
Ummm, so I found out at a car stereo place today that JL Audio is putting out a Stealthbox for the tC. It's not even on their website yet but they've sent out "coming soon" printed materials
