Inside of Clock Display cracked..
Old Aug 14, 2007 | 03:11 AM
LiquidFX's Avatar
The Family
Default Inside of Clock Display cracked..
I don't know what has happened to it, I felt the screen and it is not cracked so I don't know if the recent heat has caused it to crack or what has happened to it but I'm unsure what the cause could be. The rest of the HVAC lights don't work either, the display screen lights up until I turn the lights on and then it goes off, but the small button lights work. I don't think that I have done anything to cause this. I did install a NAV system a 3 weeks ago but it worked fine for a couple of weeks. I have noticed that the light behind my HAZARD button does not work, in fact I don't think it has ever worked. I didn't notice it until one of my friends pointed it out.
Old Aug 14, 2007 | 03:19 AM
ScionJim23's Avatar
The only way i see that it could crack is if you tried to remove the LCD to do a led swap. There is a plastic cover that covers the LCD to protect it from the outside. Im not sure if the heat could do that. I've never seen heat nor sun do that at all. Only seen these crack when people do LED swaps incorrectly. Not sure man
Old Aug 14, 2007 | 03:22 AM
LiquidFX's Avatar
The Family
i have never taken it off to do a swap or anything for that matter. i wanted to know how hot it got in there and i check one day it got up to almost 140 inside and 98 outside......
im going to go to the dealer tomorrow and let them look at it.
Old Aug 14, 2007 | 03:54 AM
engifineer's Avatar
If it wasnt taken apart, the only way I know is if something hit it or pushed on it (I have helped someone find a replacement for one because a friend of thiers pushed on it and broke it).
If you need a replacement HVAC I may be able to point you to a few good, cheap sources.
Old Aug 14, 2007 | 03:57 AM
LiquidFX's Avatar
The Family
im hoping that the dealer doesnt try and blame this on me but in case he does where is the cheapest place
Old Aug 14, 2007 | 04:10 AM
equinox2355's Avatar
well you can bet that the stealership will do everything they can to not warranty it.... but good luck anyway!
Old Aug 14, 2007 | 04:06 PM
josh4201's Avatar
I had the same thing happen to me too. What about your lights? my lights did the same thing as yours when i installed my head unit. I took my car to the dealer and they replaced the main circuit board behind the display, but it didnt bring the lights back.
After that they blamed the wiring on the h/u because they found the - and + dimmer on the h/u hooked to the - dimmer on the after markt wire harness.
I dont know what to do either the dealer cost too much to have them find the problem so i just put some led lights shining on the display to see at night.
I wouldnt have wired two negatives w/ pos. But my (so called friend) did the wiring and f&*# it up.
If anyone has any sugestions how to fix this please help!!!!
P.S. My X friends father tried to fix it rigging up lights for behind the screen when he cracked the screen.
Old Aug 14, 2007 | 04:46 PM
ScionJim23's Avatar
Sounds to me like your friend and his father have no idea what they are doing electrically and should stay as far away as they can from electronics. Wiring an H/U is not hard at all and you have to be not paying attention at all and not caring to crack the LCD screen from the back considering that it is in a plastic housing.
Old Aug 14, 2007 | 07:20 PM
josh4201's Avatar
thats why he used to be a friend. After that happened his father acted like he didnt do it and wouldnt pay for the damages. so i told him to stay away and act like he never met me. I have no tollerance for people like those to ( 2 faced ***** Fu@!#*).
If you want something done right just do it yourself.
I hope someone on here could help me figure this crap out!
Old Aug 14, 2007 | 08:28 PM
engifineer's Avatar
Well, if the wiring did fry it you can always find a salvaged hvac. If you had the leds swapped, I can help you find one and work in the swap for a good deal if you like What year model is it?
Old Aug 14, 2007 | 08:36 PM
LiquidFX's Avatar
The Family
the dealer is going to order the part and fix it all up. yay for me
qtong
Scion tC 1G ICE & Interior
Jul 14, 2010 08:13 AM
FaTaLD33
Sep 23, 2009 03:25 PM
chukde
Dec 8, 2008 11:24 PM
bushidosoul
11
Apr 2, 2007 10:39 PM
bcnu_702
Jan 19, 2007 05:42 PM
