New Wheel Fitment Thread
Old Nov 12, 2010 | 05:11 PM
  #361
RA31925's Avatar
i know that the guide is definitly not perfect. but for some reason im running 18x8 with 225/40's and the guide showed that it was supposed to be tucked, but im rubbing pretty good. im only dropped on TRD's too. oh well the guide is just a guide and was close. good enough for me
Old Nov 12, 2010 | 06:16 PM
  #362
09SocalTC's Avatar
Old Nov 12, 2010 | 06:46 PM
  #363
GQQSE13's Avatar
im running basically same set up as you except for 245/40 for tires on 18x8 and tuck but no rubbing on TRD's
Old Nov 29, 2010 | 04:28 PM
  #364
SHHH_tC's Avatar
Revoluscion
need a lil help....i got
19X9.5 +22
19X8.5 +30
and im running a widebody but the original tires i got where
245/35/19
265/40/19
but they didn't fit! so i need to get replacement tires but alot smaller size so what should i get?
please PM me....or shoot me an email jeff@seven42.com
Old Nov 29, 2010 | 07:24 PM
  #365
davedavetC's Avatar
What do you mean they didn't fit? And those sizes are pretty weak for widebody....
Old Nov 30, 2010 | 07:27 PM
  #366
SHHH_tC's Avatar
Revoluscion
tires where too tall i guess it was clipping the corners....i also have a 25mm adapters...
Old Nov 30, 2010 | 09:58 PM
  #367
wild1413's Avatar
go with a 35 series tire for the back go with a 235/35/19 that will give you a nice strech in the back. For the front i would go 215/35/19 that should work.
Old Dec 1, 2010 | 02:49 AM
  #368
JohnnyNino's Avatar
Unhappy sticky help!!!!!
18x8 +40 in the front
18x9 +20 in the rear
tires are 215/40/18 in the front
and the rear are 225/40/18
i have major rubbing driving straight!
rolled fenders and removed fender liner also have done modification(cutting) to the rear bumper!
i have a 1 inch spacer in the front also help thanks johnny!
pm post reply or call me 951 742 9011
Old Dec 28, 2010 | 01:42 AM
  #369
supercharged07tc's Avatar
iam planing on getting some 17x9 wheels, i have hotchkiss lowering springs, my question is do i have to get different offset for the front and rear so they will look the same? i am looking for something a little wider than what i have rigth now (7.5) i want it to look flush. thanks
Old Jan 5, 2011 | 06:18 PM
  #370
lastnamethai's Avatar
235/40 R17 tires on 17x9 +28, can't picture it in my head. I'm assuming it's going to be a tiny stretch since I read someone put 245's on 8's. My other option is 215/40 R17, but I'm maxed out on Tein SSP's so I won't be able to pull off the flush look. Suggestions on either 235 or 215?
Old Jan 6, 2011 | 11:30 AM
  #371
Skeeeett's Avatar
i dont understand how people can be rubbing on these tire sizes your putting up...im at 18x10+13 all around with 225/40 and im barely rubbing, only on big dips
people with 18x8 should nottt be rubbing at all thats all im saying...
Old Jan 9, 2011 | 03:54 AM
  #372
Cabana's Avatar
I'm on H-Tech, will there be any inner clearance issue with either of these combos?
18x8+38
18x9+38
18x9+31
18x9.5+30
Old Jan 10, 2011 | 09:57 PM
  #373
Aroddalobster's Avatar
you'll be fine on either setup. no more blitz?
Old Jan 12, 2011 | 02:39 PM
  #374
Cabana's Avatar
I've wanted 18s since the day I got these, just considering some options.
Old Jan 16, 2011 | 08:04 PM
  #375
ufgatorswr's Avatar
Will 205/40/17s fit on the stock rims without any rubbing and without having to roll my fenders?
Old Jan 16, 2011 | 08:11 PM
  #376
MooSE55's Avatar
I'm not sure why u would even think you would rub..ur stock tires are bigger..No point putting a 205/40 on the stock rim..
Old Jan 16, 2011 | 08:33 PM
  #377
ufgatorswr's Avatar
Sorry didn't mean to sound like an idiot there should have thought it through for a second, only reason I'm putting them on is becuase I need tires bad all mine are bald and im on the donut, I have these laying around and I'm short on the cash end so having these put on for temp use I think they will look alright, cars real low as it is
Old Jan 28, 2011 | 02:46 PM
  #378
jono06tc's Avatar
Hey guys, im about to pick up some wheels that are 17x9 et20. i figured id be nice and flush in the back, but how about the fronts? is 20 too much? ill hopefully be on stance coilovers soon.
Old Feb 5, 2011 | 05:36 AM
  #379
digital_assassin's Avatar
Default What size tire for 18X9.5 et35 on TRD drop
I've read through this thread and many others and I know I should just trust the chart on the first page and I've seen people like tCs_are_life717 on 18X9.5 et35 with TRD drop (Springs/Shocks/Struts) running this size wheel so yes, I've searched. Seems like everyone with a 18X9.5 et35 wheel is running a 225/40/18 which is pretty stretched IMO and not really to my liking unless absolutely necessary.
The TRD drop is pretty mild but fairly stiff. Can someone help me determine what size (width) tire I can put on this size wheel and not risk mangling the fenders. I have no problem with rolling fenders I just have no desire to pull. I think I may have seen someone running a 265 or 275 but I'm not sure, so many posts to look at.
Sorry if this is a noob question. Just looking for some reassurance here before spending the money.
Old Feb 5, 2011 | 12:46 PM
  #380
Jon's Avatar
Jon
Moderator
Moderator
You could put 255s on and be ok probably. 265-75 is overkill.
