Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
HID Help Thread
Old Apr 27, 2012 | 11:26 PM
  #381
alicia1984's Avatar
Yeah, I wouldn't go any higher than that. No clue how strict cops are about stuff like that around here and it's just too blue for me. I want nice bright lights that look nice if possible. I had heard here and there that some people had a hard time driving in the rain because of how the light reflects off the water. I have issues with my stock lights in the rain (newly paved roads are the worst) and I didn't want to "upgrade" to something even worse.
Old Apr 28, 2012 | 03:20 AM
  #382
chicagokid's Avatar
I have 6K at 35W and it's kinda useless in the rain. It's hard to see the road/pavement and the lines.
Maybe if I get OEM fogs with bright yellow bulbs, it might help a lot to see the wet road?!? Anyone have any experience with this?
Old Apr 28, 2012 | 06:48 AM
  #383
12stormtroopertc's Avatar
I have 8k 55w headlights and 6k 35w fogs and have no problems during the rain or any other time.
Old May 22, 2012 | 03:58 AM
  #384
XerotC's Avatar
So I got my Onex slim 35w 6000k... they came with a pair of "OEM connector to Ballast" cables. Do i need them? it looks like i could just connect my ballast directly to my OEM connector. gimme a sec lemme see if i can post pictures.
EDIT: NVM my room has poor lighting. they remind me of the cable biglilsteve posted a the beginning of the thread
http://i1089.photobucket.com/albums/...steve1/HID.jpg
hey biglilsteve, when you took them off, did you use them or did you toss them?
Old May 22, 2012 | 11:57 PM
  #385
biglilsteve's Avatar
I used all the cables that came with the kit. Your ballast won't be able to connect directly to the oem connector without using the supplied cable. You install yet??
Old May 23, 2012 | 03:28 AM
  #386
XerotC's Avatar
lol, thanks biglilsteve, i did some youtube searches and saw where that cable goes. i'm ganna give it a try this long weekend, still doing pre-installation planning like where to put the ballasts. also the passenger side has me a little worried since i have such chubby hands.
Old May 23, 2012 | 01:51 PM
  #387
Hey don't worry about chubby hands man. I highly recommend ballast placements that Enzie used (check page 5 of this thread). And also the passenger side looks tight where you are putting in the bulb, but as soon as you remove the washer fluid tube it gets way easier.
Old May 25, 2012 | 05:40 AM
  #388
XerotC's Avatar
so its ok to put the ballast in the gaps on the sides?
how do you remove the wiper fluid tube?
Old May 25, 2012 | 12:44 PM
  #389
Yup that placement is ideal and many of us here have gone with it. And removing it is in the users manual in the changing headlight bulb section. But basically you take out that black plastic pin that secures it near the top and pull it right up. Very easy/simple.
Old May 26, 2012 | 06:30 PM
  #390
XerotC's Avatar
alright guys, i installed my HIDs. the most fun part was mounting the ballast, the worst part was putting the bulbs in. scary.
my kit was a little funny because i had to reverse the polarity on the passenger side, but not the driver side. rather than move the ballast and bulbs back and forth i'll just leave it well enough as is.
now for the fun part. mounting the ballast.
since i have slims, i didn't wedge the ballast into the side gutter, nor did i use double sided tap or any tape at all.
I USED ZIP TIES. we'll see if my ballast will dislodge, but i'm pretty confident.
Driver side
passenger side
what you dont see in the photo is, i made a vertical and horizontal harness (not an electrical harness) wrapped around my ballast. the vertical is meant to hold down the horizontal, and the horizontal is holding down the zip tie wrapped around the gap. redundancies were created to prevent a single failed zip tie from letting loose the ballast in my engine bay.
i zipped tied the bundle of wires into a single bundle
unfortunately there were casualties. 20 zip ties lost their lives during the installation of these HIDs *salute*
i did this in the morning, so i didnt take any photos of the 35w 6000k HIDs, maybe later tonight or something
many thanks to the advise from biglilsteve and seeing kidjustin's set up and this thread!
opps, i dindt realize my VIN was in the photos let me edit them out and repost them
Old May 26, 2012 | 06:51 PM
  #391
:-D
Old May 26, 2012 | 07:04 PM
  #392
KidJustin's Avatar
DaYUUM/Scion Evolution
Originally Posted by biglilsteve
:-D
x2
and we will never forget those 20 zip ties! today will be their memorial day!
Old Jun 1, 2012 | 10:42 PM
  #393
alicia1984's Avatar
I'm having a really really hard time getting the passenger bulb in. I've been at it for an hour or more. No matter how much I twist the stupid thing it won't stay. It's loose. I'm so frustrated I'm bout ready to quit. The factory bulbs pop in no problem. Drivers side gave me a little trouble but it's in.
Old Jun 1, 2012 | 10:51 PM
  #394
The HID bulbs are definitely tougher to get in. My advice is to double check to make sure the rubber o-rings are properly positioned on the bulb. They are thicker than the ones on the OEM bulbs so they definitely require more strong-arming.
Did you take the washer tube out to give yourself more room to work with?
Old Jun 1, 2012 | 11:02 PM
  #395
alicia1984's Avatar
i didn't remove it but i popped it up and twisted it over. How do i take it out? Just push on the bottom of that pointy screw?
Old Jun 1, 2012 | 11:04 PM
  #396
Yeah exactly. The black plastic push thing is all you have to take out.
Old Jun 1, 2012 | 11:06 PM
  #397
alicia1984's Avatar
So i just push on it real hard from the bottom? I gave it a tentative push but didn't feel and give and i didnt want to mess with it just in case thats not how you do it.
Old Jun 1, 2012 | 11:09 PM
  #398
Yeah you can either push it from the bottom or use a flat headed screw driver to pry it from the top. It won't break
Old Jun 1, 2012 | 11:13 PM
  #399
alicia1984's Avatar
I figured that part out but honestly if i ever get this damn thing it'll probably last a day with all the abuse ive put it through.
Old Jun 1, 2012 | 11:14 PM
  #400
alicia1984's Avatar
Lol i figured out if you push the little hole in the middle it flies right out. Im taking a breather cause i'm suffering from rage at the moment. Why cant it be as easy as the damn stock bulbs?lol
