Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
HID Help Thread
Old Jun 9, 2012 | 01:55 AM
  #441
alicia1984's Avatar
So my Morimotos came in earlier this week and I didn't get around to putting them in until today because I was afraid of a repeat of last Friday. In every possible way these bulbs are like night and day. They went in on the first try with no issues and the color even in the daytime was so much whiter than the DDM bulb. I'm happy with the purchase so thanks to you Steve. Only issue I had was when I went to leave my friends house she told me to turn them on to check them out and when I shut the door to go look the drivers side light turned off. I popped the hood and made sure everything was in good and it was so hopefully it was just a fluke?
Old Jun 9, 2012 | 05:02 AM
  #442
hidkid's Avatar
i need help my hi beams dont turn on...i was installing a relay kit that i got from hid extra..i think i messed it up got angry with it and tossed it somewhere...so im going back to the stock halogens 9005 bulbs till the slim kits get here..(the bigger bulky ballast take up a lotta space where i have them)...now i put the 9005 bulb plugged them in and they dont turn on... i checked the cluster to see if the hi beam indicator shows up and nope nothing..but i do hear the clicking sound when i press it forward and do the flash to pass..
Old Jun 10, 2012 | 12:26 AM
  #443
biglilsteve's Avatar
I'm glad you like the Moto's!! I'm a bit jealous because I wish I had them for my headlights. I only have them in my fogs lol.
And I do hope that little issue was just a fluke. Keep us posted during the coming weeks letting us know how the reliability is
Old Jun 10, 2012 | 12:28 AM
  #444
Honestly man, I wouldn't bother with HIDs for your high beams. It's pretty useless since they take awhile to warm up. The point of high beams is to have the extra light you need instantaneously.
But to get them back working, you should make sure you didn't blow a fuse somewhere. It's got to be as simple as that...
Old Jun 11, 2012 | 08:03 PM
  #445
oblivionlord's Avatar
Originally Posted by biglilsteve
Morimoto bulbs are fantastic. I have 4300k Morimoto 3Five bulbs (paired with the 35w DDM ballasts) for my fogs and they have fantastic color. They are very true to their color ratings...much more accurate than the DDM bulbs.
If you get the 5000k Morimoto 3Five bulbs for your headlights, you'll get exactly what you're looking for.
I'm so tempted to get the entire Morimoto 5Five kit with ballasts and everything and just be done with the DDMs.
If your DDM are working just fine then what's the reasoning to change them out for the Morimoto?
Old Jun 11, 2012 | 08:41 PM
  #446
KidJustin's Avatar
DaYUUM/Scion Evolution
^^working fine vs working better
in Stephen's opinion Morimoto bulbs are truer in color. The DDM kit (ballast + bulbs) works fine for what they give you
Old Jun 11, 2012 | 09:45 PM
  #447
He is using the DDM Ballast + Morimoto bulbs not DDM bulbs. He wants to change out the already working DDM Ballast infavor of the Morimoto Ballast.
Old Jun 11, 2012 | 10:24 PM
  #448
KidJustin's Avatar
^^i see understood.
i thought u were talking about what he has already done and not what he was "tempted" on doing it
i'll let Stephen handle it futher, but i believe it's like "I drive my Scion and its a fine and dandy no problems, but maybe I'll go get a Porsche because its just a better car"
Old Jun 11, 2012 | 10:55 PM
  #449
Perhaps, but at least with the Porsche you can flash it around to the public or however you like and have them admire its beauty and power over the Scion. hehehe
I don't think the same would apply for a small electronics device hidden under the hood and especially the fact that it would only be recognized by those that even know what a Ballast is.
Old Jun 12, 2012 | 05:05 AM
  #450
Morimotos have super quick startup/warmup (equivalent to OEM HID setups) and have rock-solid reliability. My DDMs are starting to show their age. Occasionally they start to flicker and I have to cut them off and back on to get them to stop. I also can't have them on when I start my car because they won't reignite properly. Just little things like this that people with quality setups don't have to worry about.
I just like to know I have the best equipment. Makes me feel better about getting in my car. Justin, same reason why you went with the OEM+ Audio setup instead of going with less expensive options that "work just fine".
EDIT: And on the subject of accurate bulb colors, it's not a matter of my opinion...it's fact. The difference between DDM's "4500k" bulb vs. the 4300k Morimoto bulbs is almost night and day. The Morimoto 4300k is a really nice "daylight" color (as a 4300k bulb should). The DDM bulb is way too cool and is closer to 5500k. Even alicia saw the difference.
Old Jun 12, 2012 | 07:11 AM
  #451
Wouldn't the Meng Motorsports v2 HID kit be just as good in terms of quality and accuracy to the true form of 4300k just as Morimoto is? There's also that durability test with the kid using the hammer on it while it still functions also the submerged test with it still shining.
The Meng v2 Kit is $120 4y warranty
The Morimoto Elite Kit is $150 5y warranty
$30 difference isn't that much but the 1y extra could be worth the $30 extra
Old Jun 12, 2012 | 02:31 PM
  #452
kada90's Avatar
Noob question, again, if I want a higher light output while not spending too much money. Should I go with the DDM 55w/ 5000k bulbs? or the same ballast but with Morimoto 50w 5k bulbs? What I am looking for is for a true white light output. And for the foglights, the same configuration? what type of bulbs for headlights low beam/highbeam and fogs? Any help would be greatly appreciated.
Old Jun 12, 2012 | 02:53 PM
  #453
And when it comes down to that, I will stick with a brand that I trust as well as many retrofitters. I'm sure the Mengs work great, but I'm sure if you go to HIDPlanet forums, Morimoto is going to be the brand you are recommended every time (after OEM setups like Denso and Matsushida of course).
DDM 55w 4500k is going to be what you're looking for if you want pure white without spending a bunch of money. It's the setup I currently have for my low-beams and it looks nice. There isn't any yellow in them.
Old Jun 12, 2012 | 03:50 PM
  #454
kada90's Avatar
DO I need the error eliminator and harness for the 55w?
Old Jun 12, 2012 | 11:48 PM
  #455
Negatory. Just buy the kit. No error eliminators, no harness.
Old Jun 13, 2012 | 12:31 PM
  #456
kada90's Avatar
Not sure what you meant by "Negatory". From what I have been reading about the Morimoto Kit, I guess I'll save up a bit more and get the 5FIVE ballasts and bulbs. A little pricey ($160) but it'll be well worth it. These is the kit, right?http://www.theretrofitsource.com/pro...roducts_id=242.
Thanks for your help biglisteve.
Old Jun 13, 2012 | 03:48 PM
  #457
KidJustin's Avatar
Negatory = No
Old Jun 13, 2012 | 08:59 PM
  #458
Noooooo, that's the D2S kit. You want the H11 kit found here:
http://www.theretrofitsource.com/pro...oducts_id=3955
The H11 5Five costs the same as the H11 3Five for some reason.
And thanks for clearing that up KJ haha.
Old Jun 14, 2012 | 11:30 AM
  #459
kada90's Avatar
Thanks for the clarification KidJustin and biglilsteve. Great help.
I am such a noob at this sort of stuff.
Old Jul 2, 2012 | 04:29 AM
  #460
Jiggavolt's Avatar
I ordered these in 5000K:
Amazon Amazon
The ballasts slide up the frame rail on each side of the engine bay and "lock" in at the top. Snug enough that they haven't budged since installation 3K miles ago. Super clean and easy.
Looking at the HIDs from an angle, they look blue-purple-ish. Straight on, they're tinted with blue but mostly white. But the light they output is PURE white and very high-quality (35W). No ballast required, and the lights turn on and off instantly because of the digital ballast. No delay at all. An amazing deal for the price, and the 5000K is that perfect "expensive car" look.
