Beefing up my 1nz-fe project started
Old Jul 5, 2008 | 09:07 PM
  #81
Crippie's Avatar
1UP Crew
caught this project kinda late, but love the progress.... cant wait till you get the #s... good job on a properly built motor
Old Jul 6, 2008 | 11:01 PM
  #82
xa007xa's Avatar
here's a few shots of the kaaz lsd with the ring gear installed. am waiting on the bearings which should be here tuesday.
shots of the motor with alternator, a/c condensor, and clutch installed (cm stage 3):
running list of mods:
wiseco 9:1 pistons with swain gold thermal coating on dish and poly coating on skirt
crower rods
toga hp bearings
perrin fuel rail
fidanza flywheel
clutchmasters stage 3
unorthodox crank pulley
kaaz lsd
koyo radiator
blitz radiator cap
samco hoses
greddy rs bov
greddy xb turbo
greddy xb intercooler
greddy airinx intake
aem tru boost controller
emanage ultimate
plx devices wideband O2 sensor/controller
tanabe sustec front strut bar
gtspec rear strut bar
eibach pro springs
trd rear sway bar
h&r 15mm rear spacers
rear camber shims
eibach front camber bolts
greddy sp2 exhaust
ingalls stiffy torque damper
jp vizage front lip retrofitted
kazera kz-a dual pcd 17x7.5 rims
falken azenis rt
damn right that the mods cost more than msrp of the xa!!!!
once i pay off the note, I'll buy a new daily driver and turn it into a track car.
Old Jul 6, 2008 | 11:59 PM
  #83
jct's Avatar
jct
all you need now is the TRD rear lower frame brace
Old Jul 7, 2008 | 02:58 PM
  #84
sdsnybny's Avatar
while you have it apart you might want to think about these suspension upgrades from energy suspension
By popular demand now available for 2004 to 2007 xB!
Made from the exclusive HYPER-FLEX™ performance polyurethane material.
Save $$ and shipping by getting all the goodies together!
You will get a set of each of the following.
•Polyurethane Front Sway Bar Bushings and Endlinks
•Polyurethane Rear Trailing Arm Bushings
•Polyurethane Front Control Arm Bushings
•Polyurethane Motor Mounts
http://www.365motorwerks.com/index.a...ROD&ProdID=476
Old Jul 18, 2008 | 09:51 PM
  #85
xa007xa's Avatar
well, here's the latest:
first off, i went to home depot and bought some poly urethane and did 2 of the 3 motor mounts.
the motor went in nice. i hoisted it through the top and then dropped it down in the engine bay. then i bolted the tranny and hoisted it up again and locked it in. the greddy xb intercooler piping was a nightmare. first off, the pipe coming off the turbo was wrong. it was supposed to be a 90 to a straight and another 90 in the shape of a U. however, it was two 90's with a 90 twist. in short, i hacked up the pipe and turned it into a backyard special with the help of couplings from the hardware store.
she fired up and took her out. however, the "old" heat shield wrapping i had on the shifter cables finally gave in and i melted one. now i am in a holding pattern waiting for a new cable. in the meantime, i'm going to tidy up the wiring and connect my wideband controller and pressure sensor to emanage. i ended up ordering the greddy universal intercooler piping kit and hopefully that will make the piping look nicer. will post pics after i redo the piping.
still waiting for the flange for the bov. the kaaz lsd was responding nicely. didn't want to beat on the car, but i applied some power that would have made the wheels hop a bit with the stock dif without hopping. also, the 9:1 compression got rid of the high pitched exhaust sound, sounds more throaty now.
Old Jul 18, 2008 | 10:20 PM
  #86
Black_Sheep_xB's Avatar
nice looking build.
Old Jul 21, 2008 | 01:30 AM
  #87
uber-xA-RS2's Avatar
The stock layout of the Greddy charge piping is not the best.
You need something more like this:
One thing that I have found out about the charge piping: It heatsoaks very easily in our xA engine bays. Do what ever you can to get cool air running into the space occupied by the stock airbox and lower your charge pipe temps. I will be wrapping the cold air line from the intercooler to the throttle body with heat wrap to keep charge temps down.
Looks great!
Old Aug 1, 2008 | 03:26 PM
  #88
wilvitz's Avatar
hi, i am doing up my engine at the moment. Need some help to buy the con-rod , piston. Do you have a diamension of the con-rod and piston? Do you have a diagram or a pic with measurement of both of these? Pls help
will,
Singapore
Old Aug 1, 2008 | 03:47 PM
  #89
wilvitz's Avatar
Hi, i need some help from you.Your crower rods and the wiseco pistons is custom made or off shelf? I am looking for a engine kit for my yaris. where and how did you order it? Do you have a diagram showing the full measurement of the con-rod and piston? Pls help .Thk you.
Will,
Singapore.
Old Aug 12, 2008 | 02:48 PM
  #90
vettereddie's Avatar
Will,
Can't answer you on the pistons, I got them from xa007, so I don't know if they were custom or not. I couldn't find the 1NZ listed on Wiseco's site, so I'm assuming they were. They came with wrist pins and rings.
Here are the Crower rods, they are no longer a custom part.
http://www.crower.com/cgi-bin/detail...o.x=10&go.y=13
Dezod is also a Crower supplier and actually has them a little cheaper. Paul didn't even know they were being made until I PM'd him, but they went up on the Dezod site that day after I let him know. PM him first before ordering, they may have an additional SL discount.
http://www.dezod.com/cat-connecting.cfm
The toga HP bearings can be gotten from import performance parts, along with rings, etc if you don't have them already.
http://www.importperformanceparts.ne...ngs-scion.html
Here's ecerything else they have for Scions:
http://www.importperformanceparts.ne...ortsscion.html
Old Aug 12, 2008 | 04:03 PM
  #91
xa007xa's Avatar
the pistons are custom order from wiseco. order the engine kit from ipp and you'll get the pistons, bearings and gaskets. the pistons I sold to vetter came with the kit. I bought it off of someone else and the compression was too high. I ordered a set of pistons only from ipp for my setup. took about 5 weeks. ipp has great prices. oh, and I recommend getting the service manual.
Old Aug 13, 2008 | 02:15 PM
  #92
firesquare's Avatar
may be a little late but heres a good transmission company that can build what you want.
http://www.rsgear.com/
their located in NY about 20 miles north of NYC. if they can build a race tranny for a viper. i think our little 1NZ-FE motor will be easy for them. :-)
Old Aug 14, 2008 | 07:12 PM
  #93
Icecreamtruck2005's Avatar
Default Updates
Any updates on your project?
Old Aug 14, 2008 | 08:28 PM
  #94
Originally Posted by xa007xa
blitz radiator cap
Wow, with all the other awesome mods you still felt inclined to list this one too?
What are you doing for an oil cap? I've got a Greddy anodized blue for sale.
Oh, and who did the piston coatings?
Old Aug 15, 2008 | 04:13 PM
  #95
Default Update
So is your box done, did you tune it and now are driving it around.
Old Aug 15, 2008 | 05:10 PM
  #96
xa007xa doesn't have a box, it's an xA. Just gonna have to wait for him to post an update.
As for my build, I haven't even cracked the block open yet, still ordering parts.
Old Aug 15, 2008 | 06:32 PM
  #97
xa007xa's Avatar
done. just need my piping welded and then off to the dyno
Old Aug 15, 2008 | 06:52 PM
  #98
garabaldy's Avatar
watching
Old Aug 15, 2008 | 11:10 PM
  #99
JSosa's Avatar
sweet.... Where are the pictures?
Old Aug 16, 2008 | 11:53 PM
  #100
Sorry to threadjack but I felt I had to share:
https://www.scionlife.com/forums/vie...635&highlight=
Thanks again for the pistons.
