Brake Lights - 2 of 3 Don't Work
Old 10-26-2018, 10:47 AM
douglasinct's Avatar
Question Brake Lights - 2 of 3 Don't Work
2005 xB (201,000 miles)
A nice policeman informed me yesterday that my car's Center and Passenger Brake Lights were not working.
- Only the Driver Side one works.
I am confused by the fuse block diagram labeling.
It seems that only one fuse (#16) controls ALL Stop Lights (brake lights).
- Will check Fuse #16 later this morning.
Does this car have two circuits to prevent total Brake light failure in case of 1 fuse being blown?
(e.g. one fused circuit for the driver's side brake light, and one for the Center and Passenger Side brake lights?)
Thank you.
douglasinct is offline
Old 10-26-2018, 02:47 PM
Big_Jim's Avatar
Have you started by checking the bulbs/harness? Do your signal indicators work? I'd start there before diving further into circuit issues.
Big_Jim is offline
Old 10-26-2018, 02:50 PM
drizzoh's Avatar
Definitely start with new bulbs. 99% of the time they're the issue.
drizzoh is offline
Old 10-27-2018, 02:44 PM
RichBinAZ's Avatar
Doesn't the owners manual tell you how to change the bulbs???
https://www.toyota.com/owners/resources/owners-manuals
RichBinAZ is offline
Old 11-03-2018, 05:10 PM
Thumbs up
Thank you, all.
- I really should not over-think things, but take them one step at a time.
I just changed the center (3rd) Brake Light bulb.
And.... it works!
Tried to change passenger side Brake Light bulb, but find it will be easier to remove the whole tail light assembly (2 easily accessible nuts), replace the bulb, and reinstall the tail light assembly.
All I have to do now is find that 10mm socket.
- I know that it is on the end of a socket wrench.... somewhere.
Old 11-04-2018, 04:45 AM
Big_Jim's Avatar
Originally Posted by douglasinct
Thank you, all.
And.... it works!
you need to remove the tail light assembly to change the bulb. theres a little panel that pops out on both sides inside the hatch.
Big_Jim is offline
Old 11-18-2018, 09:15 PM
Had to borrow a neighbor's socket and drive, but just found mine today... behind the tool carrier on the work bench.
- How it got there I will never know
Anyway, took off the inside panel door and got my wife to reach up and replace the bulb.
No change.
Next step is to trace power.
- Grr...
Old 11-25-2018, 01:06 PM
RichBinAZ's Avatar
This link might help with locating where the wires run - I wonder if you have critters gnawing on wires - it can happen!!
ktwo
Scion tC 1G ICE & Interior
09-09-2017 04:15 PM
Dayyyum_tc1
08-27-2017 04:45 AM
ixoye
Scion tC 1G Aero & Exterior
11-18-2009 03:18 AM
Kvizzel
10-10-2009 07:58 AM
Big_hungry
04-02-2006 06:41 AM
Quick Reply: Brake Lights - 2 of 3 Don't Work
