THE Short Throw Shifter Thread
Old Mar 28, 2008 | 10:21 PM
  #441
Stealth_Fighter_tC's Avatar
Originally Posted by unxpectederror
you can use the trd cage but why mess that all up why not use the stock cage that you already have lying around
Cause for some reason after moving out of my ex's house, I cant find the OEM shifter and cage!! And OF COURSE she doesn't know where its at!!
Old Apr 6, 2008 | 06:18 AM
  #442
x_Batman_x's Avatar
Got my Dr. Isotope gearswitcher in, it's great :D . Ended up going with a 2" height reduction:
Oh also, I'm somewhat confused about the cable bushings which I have yet to install. I looked at install guides for other companies' bushings to get an idea of what I was going to do with Doc's delrin bushings, however all other companies only give you 2, while Doc includes 4... how exactly do I install these things?
Old Apr 6, 2008 | 02:59 PM
  #443
ddplion's Avatar
^^^ i have wondered the same thing ,,,2 and 4 ???
Old Apr 6, 2008 | 04:11 PM
  #444
When i got my NST for my tC, I got 2!
Old Apr 6, 2008 | 05:21 PM
  #445
engifineer's Avatar
Docs go in as a sandwich. So they are basically 2 peice bushings. From what I can tell, that i the very best way to make them that hard and still be able to fit 100% correctly in the cable ends.
Old Apr 7, 2008 | 04:22 AM
  #446
x_Batman_x's Avatar
Oh darn engifineer beat me to it lol. I made a DIY and everything. Oh well you guys mught find it helpfull just the same :-):
https://www.scionlife.com/forums/vie...343831#3343831
Old Apr 9, 2008 | 10:34 PM
  #447
Can someone point me in the right direction...I'm trying to find out how to UNinstall a TRD shifter and cage!!!
Old Apr 9, 2008 | 10:36 PM
  #448
yellowxhoodie's Avatar
ordered my Doc I's a couple days ago. :D
Old Apr 9, 2008 | 10:45 PM
  #449
ddplion's Avatar
here is a start:
http://www.doctorisotope.com/index.p...d=26&Itemid=25
https://www.scionlife.com/forums/vie...ht=shifter+diy
other then that there are 4 bolts and then the 2 connections that clip on the end of the cables. IT is a little tricky getting the 2 cables out of the there. You have to turn the connection piece but there is a spring keeping it tight
Also, the search is very helpful ... I put "shifter diy"
Old Apr 10, 2008 | 01:12 AM
  #450
here is a start:
Thanks! I did a search, but I was being specific. Didnt know something simple like that would get me the result I needed!! Thanks again!
Old Apr 10, 2008 | 04:00 AM
  #451
scion_soup13's Avatar
Hey, so Dr.I is only a modification to the "shifter arm" itself?? You can use the original cage and stuff. And, if so.. does shortening the arm, also shorten the throws?
Old Apr 10, 2008 | 04:16 AM
  #452
AdmirN's Avatar
Anyone have Pics of there ARK short shifter???
Also overall witch one is the best not including the price???
And for those who have a 1.5 inch drop or more doesn't your elbow hit the arm rest when shifting to 1st to 2nd and 3ard to 4th???
Old Apr 16, 2008 | 06:24 PM
  #453
arkracing's Avatar
Here is picture of ARK V. 2 Short Shifter !! Currently we have sale price listed www.arkspeedracing.com
Here is comparation ARK V.2 vs TWM stage 2 result from TC member.
https://www.scionlife.com/forums/vie...217194&start=0
Old Apr 17, 2008 | 01:36 AM
  #454
AdmirN's Avatar
anyone have the ARK with pics? any opinons on it
Old Apr 17, 2008 | 07:53 PM
  #455
BuddhasTC's Avatar
ok here is the ARK VII STS...excuse the **** it was temporary
it's a great shifter. It's a little taller than the TWM stage 2 (by mere centimeters) but the throw reduction is much less. paired with a weighted **** (which i now have), this makes for an excellent shifter. no missed shifts and the distance inbetween shifts is a lot shorter. Excellent product. one thing though, you cannot use the stock leather **** or the TRD leather ****. You do need an aftermarket ****, the one that ARK supplies with it though is sufficient and pretty good.
Old Apr 17, 2008 | 10:22 PM
  #456
ALTech's Avatar
Doc's bushings install like a sandwich (half on top & other half on bottom).
Here's the DIY w/ pix https://www.scionlife.com/forums/vie...c+gearswitcher
Originally Posted by TougeTerror
Here's my doctor isotope shifter. It's 1.5" reduction with the cage risers.
In most of the pix I've noticed almost everyone w/ Doc I's SS has that chrome ring on the shift boot covered. Is it possible to install it with the chrome ring intact (w/ 1.5" default reduction)?
Similar to this setup (notice the chrome ring on the shift boot underneath the shiftknob)
Old Apr 18, 2008 | 01:17 AM
  #457
x_Batman_x's Avatar
lol yeah I figured out how to do the cable bushings, infact I wrote that DIY
And yes its possible to keep the chrome ring. If you look at the pic of mine that you quoted you can actually see it, its just kinda hard because of the bad lighting... I'll have to get a better pic. You need to drill out the crome ring with a drill bit larger than 1/2" or take a 1/2" drill bit and grind out the center to acheive the same effect. I also cut off a portion of the bottom of it to make it smaller so it wouldnt interfere when I crammed it on there. You then set it up just like stock only when you slide it onto the shifer it will go over the lip of the shifter that used to hold it up. Its now held up just by the boot pushing up. I hope that made some sense
Old Apr 19, 2008 | 01:33 PM
  #458
patternofstars7's Avatar
I just got and installed my TWM stage 2 in. Took a while to get one clip out but after that it was oober easy. I love it so much! Everything just feels more natural.
Old Apr 27, 2008 | 07:37 AM
  #459
dqlostsoulz's Avatar
My Megan racing short shifter w/ my new sparco shift ****.....
I have a question what do i do about the boot......it too big now? How do make it look like the pix below............................?
[/img]
Old May 2, 2008 | 05:18 AM
  #460
Bozuzu's Avatar
lost souls, nice choice with the globe x sparco! that's what I've got! to fix your shift boot problem get the redline boot, they are awesome quality and a good price, one of my favorite mods.
http://www.redlinegoods.com/ScionTC04shiftboot.shtm
