Install Ingalls Damper
Old Nov 2, 2006 | 12:44 AM
  #241
haiduy's Avatar
dayam thats a crazy install haha since im a noob, but nice work was thinking of gettin one
Old Nov 8, 2006 | 10:42 PM
  #242
BOXMAN's Avatar
ttt! Any questions
Old Nov 9, 2006 | 12:15 AM
  #243
Tcguy85's Avatar
i just got one and i like it, i thought it was loud at first but it's ok now after messing with dynamat and rubber washers and stuff. it deffinetly does everything people say it does, easier shifts, almost no wheel hop, and it deffinetly feels like it puts more power to the ground. although i do think that the people that say it's perfectly quiet must have intakes or exhaust covering up the sound of the damper. you can deffinetly hear that it's there but it's not unbearable or anything don't get me wrong.
i think it's adjusted to about 13mm right now, i think i might stiffen it up to 12mm but it seems to make more noise when it's cold, so i might wait till spring once it warms back up again to stiffen it up.
also from reading things on here about it (before i got it) i was a bit confused on how the adjustments went, but i measured it with a dial caliper to set it and i realized it really has infinite adjustability not just the 6 settings i thought. obviously you can just measure exactly 10mm or 14mm or whatever but you can also set it to say 12.34 or 13.83 or anything you like. no sense in really setting it to a wierd number but i just noticed that... like i said i had no idea how the thing was adjusted. i just think it's cool that you can really fine tune it like that even though i doubt you would notice a difference from say 12mm to say12.5 but whatever. i deffinetly recomend the damper to anybody.
Old Nov 9, 2006 | 01:02 AM
  #244
Tcguy85's Avatar
not that there aren't pictures of them on here already but here is another...
Old Nov 9, 2006 | 04:23 PM
  #245
BOXMAN's Avatar
Its nice to see the 07 guys modding at the rate they are. Congrats glad you like it.
Old Nov 10, 2006 | 01:33 AM
  #246
Tcguy85's Avatar
i'm actually moving pretty slow with my mods. the damper was my first real mod besides putting a subwoofer in the back. i can;t seem to save enough money. i have so many things i need to save for. but i love the damper. great product even on a stock car.
Old Nov 11, 2006 | 08:27 PM
  #247
11thhour's Avatar
how do u know if ur stiffy is broken...
stiffy feels different now as opposed to the 1st time
hmm.........
and no, i did not try to adjust it.....
Old Nov 11, 2006 | 09:12 PM
  #248
BOXMAN's Avatar
Why would you assume it was broke? Is their a noise or a bang that would lead you to that thought? If not have you thought you might just be used to the part now?
Old Nov 11, 2006 | 09:43 PM
  #249
11thhour's Avatar
or maybe i am used to it... i just dont feel like its tight enough... how do i tighten it?
Old Nov 11, 2006 | 10:52 PM
  #250
BOXMAN's Avatar
go to www.ingallseng.com click on Stiffy application and download the adjustment instructions.
Old Nov 12, 2006 | 01:37 AM
  #251
11thhour's Avatar
shouldve searched....
thx btw
Old Nov 12, 2006 | 02:20 AM
  #252
11thhour's Avatar
ingalls said:
DO NOT exceed 35 ft. lbs. or the ETD may be damaged
o crap... i used the "cant get any tighter" method....
Old Nov 19, 2006 | 02:58 PM
  #253
gcxandy's Avatar
the colder weather is definitely making the rattle/vibrating alot worse. i think i will have to try these rubber washers and play with my raamat, and if that doesn't help, i'll have to loosen it.
Im guessing in the summer, the heat expands the metal so it sits better in place.
Old Nov 21, 2006 | 05:56 PM
  #254
BOXMAN's Avatar
The issue isnt the metal shrinking or expanding. The elastomer is reacting to the tempratures. The key to limit vibration is to check length of the ETD and make sure all of the hardware from the kit was installed correct and torqued down.
Old Nov 22, 2006 | 09:49 PM
  #255
Spect2K3's Avatar
What a useful thread, way to go guys!
Old Nov 23, 2006 | 08:02 PM
  #256
jetlounge's Avatar
since the question keeps getting asked, i am not the only one. the single page install instructions are inferior when compared to the great write up here on page 1. the adjustment instructions are even worse.
According to the diagram there are 3 nuts:
Preload Adjusting Plunger
Helm Join Locking Jam Nut
Locking Jam Nut
Step 3 says, ajust the "Adjusting Plunger Jam Nut". Ok I will assume that is the first item, which is the middle nut...but what do i know? it also says in step 4 that you need to tighten the Locking Jam Nut...but it never tells you when you were supposed to LOOSEN it.
can someone please confirm the proper procedure and the nuts that need to be touched in order?
The first one who answers this for me gets a hearty "Happy Thanksgiving!"
Old Nov 24, 2006 | 09:34 PM
  #257
jetlounge's Avatar
Default Re: Install Ingalls Damper
Originally Posted by Kaeon
Install bracket using the long 17mm M10 bolt, and the 14mm M10 nut that Ingalls supplies. Make sure to place the gold washer under the long bolt. Ingalls suggests blue lock tight on the M10 bolt to prevent it for coming loose.
According to the directions, that install pic and description above is incorrect.
Its the far nut that gets the GOLD washer UNDER the bracket.
The near bolt gets a normal washer ABOVE the bracket. This is in their install sheet and pictured in Illustration 2 & 3 (although i don't see why they couldn't make the pictures any bigger to make it clear).
This would appear to make sense since the far part would have the bulk of the bracket resting on the new small hex nut. The GOLD bolt would give it more 'shelf' to rest on and could be the reason for a bit of the wobble/vibration you folks experience when installing the other way.
Old Nov 24, 2006 | 10:35 PM
  #258
Spect2K3's Avatar
Can anyone confirm that this is correct? Seems logical to me!
Old Nov 24, 2006 | 11:16 PM
  #259
BOXMAN's Avatar
gold washer is placed under the bracket per Ingalls instructions
Old Nov 25, 2006 | 12:36 AM
  #260
zer0's Avatar
Yea, the DIY is wrong. I noticed that when I installed mine.. just go by the Ingalls instructions here:
http://www.ingallseng.com/Instructions/93027.pdf
